Carbon fiber hood
Old 03-22-2009, 03:05 PM
enigma34's Avatar
Default Carbon fiber hood
How do i remove the stock hood? Im looking at ones around $350 on eBay, vis i think. It says it has oem fit. Do i re use the parts on oem hood on carbon fiber hood?
Old 03-22-2009, 03:19 PM
SPLAT's Avatar
Befor you buy a hood, i have one for sale from seibon
Its easy to do the swap.
Old 03-22-2009, 03:20 PM
justinwebb's Avatar
February 2010 ROTM
you take out the four bolts holding it in and remove the hood. Then put said 4 bolts in new hood. Then close hood.
Old 03-22-2009, 04:30 PM
Keep up the post whoring and I'm going to delete every post for every account your Philippine a** has ever made.
to the OP, there's 4 bolts on the hinges (2 on each); take those off, pull the hood off (it's easiest with a friend), put the CF hood in place (again, a friend helps), and bolt the hinges to the hood using the stock bolts.
Old 03-22-2009, 06:51 PM
lowlife9's Avatar
Banned
i bought my vis hood from ebay and it was warped .if i was you i would buy directly from vis or evan better seibon they have better fittment and quality products evan the smaller companies like v-fiber are better quality because there not mass produced like vis also you have to remember no matter who you by from it wont be a perfect oem fit .also vis and many others use a gel-coat clear that will fade faster in the sun.do not use carnauba wax it will absorb into the gel-coat and turn it yellow. use a gel-coat wax designed for boats 3m makes a good one. also i would definitely recommend hood pins just to be safe evan vis will tell you this.after you remove the bolts you mite need to pry it from the hinge with a screwdriver its stuck on there from some factory material .
Old 03-23-2009, 05:48 AM
ShaTownCivic's Avatar
You should buy SPLATs. See how much he wants for it. It's most likely better anyways.
Old 03-23-2009, 11:01 AM
enigma34's Avatar
hood's WITH VENTS or screens do they let water in the engine bay/touch the air filter?
http://cgi.ebay.com/ebaymotors/96-97...Q5fAccessories
Old 03-23-2009, 11:21 AM
V8DIET's Avatar
Yes they let water in your engine bay. Yes it could possibly soak your filter if you have a CAI of some kind and an exposed filter. Hoods with vents on a DD car is not a good idea.
Old 03-23-2009, 11:34 AM
enigma34's Avatar
Thumbs up
that's good to know.
Old 03-23-2009, 11:38 AM
V8DIET's Avatar
Plus unless they are done right, they can look ricey.
Quick Reply: Carbon fiber hood
