can you repair front body kits
Old 08-02-2007 | 01:34 AM
1997civic's Avatar
Default can you repair front body kits
i recently realized that i will have to repair my body kit on the front. its fiberglass, and is there a process to fiberglassing it back together i recently hit sumhing in the road, actually tonight it was last second thing and it took a chunk out of the bottom. so input or a instruction site
Old 08-02-2007 | 01:45 AM
jeff948594's Avatar
Default RE: can you repair front body kits
i personaly would ditch the fiberglass and go with a urethane one just for that reason, but just go to menards and get a package of fiberglass cloth. and some resin. you will also need a paint brush too. clean the area that needs repair and apply resin then put a a few strips of fiberglass cloth over the crack, if is just the chip then you just have to bondo it. its unclear in ur post if its cracked too or just chipped.
Old 08-02-2007 | 04:21 AM
ksrecon's Avatar
At walmart you can just buy a fiberglass repair kit that I believe comes with everything you need.
Old 08-02-2007 | 05:39 AM
absoulute's Avatar
very hard to do if there is a chunk missing all depends if it has curves on the chunk or if its just straight. it will take along time to fix and good skills to make perfect.
Old 08-02-2007 | 02:11 PM
1997civic's Avatar
yeah there are a couple spider cracks. there is one cracked where it looks like it hit sumthin and totally cracked through. and the one i put in last night where i hit sumin in the road and took a chunk outta the bottom... it usnt on a curve or anything. is urethane expensive?
Old 08-02-2007 | 02:20 PM
mill$civic's Avatar
Its more expensive then fiberglass, but worth it in the long run if your going to have the kit for a long time. Just check out some prices for a front bumper.
Old 08-02-2007 | 02:51 PM
if you decide to repair the fiberglass bumper, here's a hint:get a few cans of expanding foam insulation (it's made for going around doorways and windows in houses... you can pick it up at wal-mart in the home improvement section). Spray the insulation on the inside of the body kit (don't use too much at once or else it'll expand too muchand crack your kit) to stiffen it up. When I did mine, I took a saw to the insulationthat was sticking out (you'll know what I'm talking about if you do this)and then sanded it all smooth. It makes the kit a little more rigid (which is really nice forsideskirts... my ex always managed to kick my sideskirts when she got into my car lol). Personally, when I get around to repairing my kit (cracked the front bumper in 3 places last winter... don't ask how lol), I'm going to be fiberglassing over (and painting) the insulation just to make it look a little better.
Old 08-03-2007 | 12:21 AM
1997civic's Avatar
well my plan for now, seeing as how i like my front bumper is to when i take it off for winter,...(i am going to devise a small plow type bumper for the front so i dont screw myself over in winter) i will repair it at school, and get it repainted
skibum853
10-27-2007 12:37 AM
InFlames235
11-03-2006 09:03 AM
FlipHKD720
09-28-2006 09:47 PM
xramseyx
04-19-2006 06:44 PM
mpilic
12-06-2004 10:04 AM
