whats the diff between stainless and mild steel exhausts
Old 05-31-2005 | 08:27 PM
FastFwd's Avatar
Default whats the diff between stainless and mild steel exhausts
does anyone know what the difference in power is between Stainless steel and mild steel.
Old 05-31-2005 | 10:37 PM
hndanut1's Avatar
Default RE: whats the diff between stainless and mild steel exhausts
stainless is more cash and wont rust, mild is a hot roll or easy to get and cheaper
Old 05-31-2005 | 10:53 PM
FastFwd's Avatar
does it produce any more HP or Torque than the stainless......
and Mandrell bend and the conventional bending - is there and hp or torque difference between them
Old 06-01-2005 | 12:17 AM
sacicons's Avatar
power is comparable between SS and mild. power with mandrel bent tubing is head and shoulders above crush bent tubing.
Old 06-01-2005 | 02:58 AM
FastFwd's Avatar
can you buy apexi N1 exhaust kits all the way threw not just cat back.....including extractors
Old 06-01-2005 | 08:48 AM
ngoti 8tor's Avatar
Stainless Steel is also a lighter header than Mild Steel since Stainless is a stronger material. Also, since the stainless is made thinner, the sound will be a bit more of a "pinging" noise than with the thicker Mild Steel.
IMO, I would get a Creamic Coated Header which is Mild Steel with Ceramic on top. They're thicker, to keep the noise down a bit more, and the Ceramic keeps more heat outa your engine bay and also helps the exhaust run thru faster and smoother.
rennaynay88
05-01-2008 08:30 AM
fivespeed
10-01-2007 11:55 PM
2slo4u
05-09-2007 08:46 AM
civicexracer
03-06-2006 06:32 PM
D16z6
12-21-2004 10:04 PM
