throttle body spacer
RE: throttle body spacer
ORIGINAL: remington870_20ga
is it still worth getting it even when you have an aftermarket intake on it?
hey you guys have no clue! a throttle body spacer is like a 1/2" to 1'" peice of metal that bolts between your throttle body and the intake manifold. all it does is give you a little more space in the intake manifold. yes it helps give horse power and tourqe. its cheap and not that hard to install and it will work with a stock manifold and most aftermarket and if you are running turbo don't realy know if you can use it or not im not that far into my ride.
