Skunk2 or Edelbrock
Old 09-21-2007 | 09:23 AM
bcrichguitars's Avatar
Default Skunk2 or Edelbrock
I have a JDM D15B
The Skunk2 says fits D15B7, will it fit my engine? I run about 9psi on stock internals, could i expect 15 hp from an intake manifold +throttle body?
Also can I run a larger throttle body or does it have to be 62mm? Here's the description:
"Skunk2 Pro-Series Intake Manifolds greatly increase airflow to your engine. The Pro-Series Intake Manifolds feature a larger intake plenum and wider, longer intake runners than stock. This provides a significant mid-range and high-end power boost for stock engines and is a necessity for any heavily modified engine with high compression and aggressive camshafts. The Pro-Series Intake Manifold is a single stage design and is a direct replacement for the stock manifold. The stock throttlebody can be reused as well as all stock sensors, hoses, and auxiliaries. Throttlebody inlet diameter is 62mm. The Skunk2 Pro-Series Intake Manifold is CARB exempt."
What do you think? Also I couldn't find a edelbrock manifold on ebay for d15b, where could i get one and are they better manifolds compared to Skunk2?
Old 09-21-2007 | 05:59 PM
warner_ro's Avatar
Default RE: Skunk2 or Edelbrock
i say get the skunk2, skunk2 makes good stuff and i would raqther have it over another brand. also the trottle body should work for your car.
Old 09-21-2007 | 07:45 PM
I was asking will the skunk2 manifold fit? It syas for d15b7, i have jdm d15b?
Old 09-21-2007 | 09:35 PM
Marty's Avatar
Yes it will fit but Edlebrock has alot better research and developement capabilities, has been around tons longer, and are known for their quality.
Old 09-22-2007 | 12:30 PM
Does Edelbrock make one for the d15b? I could only find an edelbrock manifold for the b series engines? Can I upgrade to a bigger throttle body with that manifold?
Old 09-22-2007 | 12:40 PM
KoshaK's Avatar
look at Kingmotorsports.com for throttle body
Old 09-22-2007 | 09:25 PM
Marty's Avatar
Any D series intake manifold will fit any D series engine and yes they do make one for the D series
Old 09-23-2007 | 12:40 PM
Strong Island's Avatar
ORIGINAL: Marty
^+1
just installed an edelbrock on my D15b7
Old 09-23-2007 | 03:30 PM
ORIGINAL: Marty
Ok so the only edelbrock manifold i could find for d series, said it fits "1996-00 Civic EX, D16Y8 SOHC with natural finish"
I have a 1995, D15B. this manifold will fit?
barracuda
05-18-2012 04:13 PM
stylincompact
10-14-2007 09:48 AM
travhdg08
03-20-2006 01:44 PM
05blustipa
05-08-2005 11:25 PM
KScivic
04-29-2005 09:08 AM
