Plug and Play o2 Simulator?
Anyone know where i can find one? Would clean up alot wiring in the engine bay and just be alot simpler. I've heard of PNP simulators before but i could only find ones that had to be spliced into the stock o2 sensor wires.
RE: Plug and Play o2 Simulator?
ORIGINAL: mxs
why do you need one? find out why you have a CEL first [8D]
do you have a picture of your engine bay? I don't see it in your gallery
naw i dont, i should probably get that up tomorrow.
67 = P0420 = Catalyst system efficiency below threshold
here's a cheaper fix, the spark plug anti-fouler, AKA the "spacer" trick
http://www.scoobymods.com/forums/showthread.php?t=5468
http://www.honda-tech.com/zerothread/1901557
67: catalytic converter.....or is the P0420 code just a more in-depth version of the catalytic converter code? I'm thinking the cheap high-flow cat combined with the spliced/extended secondary o2 sensor and no simulator is causing this light. I think the simulator would fix any CEL's dealing with this whole thing though.
ORIGINAL: FlipHKD720
"Catalyst system efficiency below threshold" roughly translated into ricer speak: "cat no worky!"
i read the Scooby one MXS, i've seen similar things like that, but to even get the o2 sensor to reach the 2nd sensor bung you have to extend the wires, so why not just wire the o2 simulator in while your working on it?
ek2ner_knox
18
05-25-2006 12:22 PM
