o2 simulator help
o2 simulator help
I cant make heads or tails to this thing. The simulator only has 3 wires and the stock has 4... any ideas guys? I could really use your help, my car has been in limp mode since 2001.
RE: o2 simulator help
ok i can help you but im going to have to thread jack this bitch.
my understanding: the o2 sencor has 4 wires 1) ground 2) voltage 3) heaer/ temperature 4) and sencer.
the heater is suposed to be left alone, and your o2 simulator wires are suppose to be spliced with the ground, voltage and signal and thats it.... but here is the problem on every generation honda changed the colors of the wires. but i have the same problem but i have a cure for you. take a trip to pep-boys or something and find the haynes manual. in the back i saw that in your gen. there is a wire diagram that tells you witch colors are witch...
witch brings me to my jacking.... my 01 ex has 2 white, a black and a gray.... anyone know wich ones are wich?
thanks guys for your uber help... gives me a way better idea... but keep them coming. I only get to go under my car once in awhile... idlike to get it right the first time.
ya i cut them... had to to extend them 3ft longer
i figure i can use one of these o2 sims... OR buy a new one and cut/weld a o2 sensor bung where its suposed to be....
i just dont know what to do... i see these sims but dont see any 4wire sims... only 3wires... if someone could tell me how to wire these sims in that would be great!!!!!
sucks having that sucker ON!
i read somewhere that if i soldered the extention wires it shouldnt be a problem.....
