Megan or DC sports headers?
Now i just have the choice between the two, i have heard good about both of them, i really dont care which is more, i just want the quality.......which would you do? Its a toos between either the stainless steel megan headers or the cermiac coats DC sports headers? Then i also need to know, should i stick with my magnaflow exhaust (which i can cancel the order) and get a megan exhaust?
RE: Megan or DC sports headers?
True.....So i now just bought the header and exhaust, do i need to buy O2 sensors and a cataltic converter? If so what is some good choices because im going from an LX to an EX.....so i know the exhaust is different....
Pop your hood and check if the cat is bolted directly onto your stock header. If you cant tell by that then get under it and take a look. On my DX the cat was bolted right up to the header and when I got a new header it replaced the entire stock header and cat. If this is the case you will need to buy an aftermarket cat and get it welded into your exhaust. You dont have to but you will want to because 1) w/o it the exhuast sounds like poop and 2) save the enviroment man! If it is the same setup as my DX then there is an 02 sensor that was placed in the cat that will be left out so youll then need to buy a 02simulator.
It is bolt to my stock header, where did you get your O2 sim at, i dont see any that fits civics, i went to 02sim.com and 2 other sites......would a regular 02 sensor be wiser?
