Good Paint For My Intake
Old 10-23-2006 | 04:44 PM
TheMoogly's Avatar
Default Good Paint For My Intake
Can anyone give me a couple tips on how to paint my CAI black and not make it look crappy? I want it to still be shiny but black... I got it from WestImports and it is a SIMOTA CAI... just had to throw out an add for the guy... great deal, 80 bucks and works like a dream... so what paint, how to paint... stuff like that would be great, thanks!
Old 10-23-2006 | 05:27 PM
amg6975's Avatar
Default RE: Good Paint For My Intake
I would imagine just some regular old rustoleum would do the trick. Make sure to sand down the metal really good first though. If you can find some ceramic insulating coating I would do that first then paint over it, keep your intake charge cooler... doubt it would do much but it'd be cool.
Old 10-23-2006 | 07:14 PM
TheMoogly's Avatar
Fantastic, thanks!
Old 10-23-2006 | 11:40 PM
D16Punk's Avatar
I dunno about you guys, but I know my intake gets real warm, most likely from the header. I'd say you may be better off with High Heat paint with a High Heat Ceramic sealer. I think you'd be good to go with that.
Old 10-24-2006 | 12:17 AM
drbyers's Avatar
i think you're better off just leaving it alone.
Old 10-24-2006 | 03:39 PM
TheMoogly's Avatar
Well it wouldn't get hot enough to need engine paint, would it? I am still going to try to paint it and if it chips off then I will go back to chrome... or heat tape it.
Old 10-25-2006 | 11:36 AM
jason98ex's Avatar
I had a chrome AEM Short Ram....I used a 320-grit sanding block, some adhesion promoter, Duplicolor MetalCast metallic base coat, and Duplicolor MetalCast Red on top. I've had it this way for about 3 or 4 months now, no probs at all as far as chipping, peeling, whatever. Unless they've seen an AEM shortie that's actually red, no one can tell the difference.
Old 10-25-2006 | 04:38 PM
TheMoogly's Avatar
THERE WE GO!!! A full answer!!! Can you post a pic of your short ram for me? This might be super dumb, but did you use a paintbrush of spray from a can? if you used a can, how far away from the intake were you to keep it from looking clumpy (many clumps or bubbles)?
Old 10-26-2006 | 08:06 AM
jason98ex's Avatar
I rattle-canned it. Spray about 8 inches away from the intake with a nice sweeping motion, and it should do you good. Anyways, I'm also pretty sure that they have a black MetalCast paint, in addition to the red, blue, purple, gold, and maybe a couple of others. I also used the red MetalCast on my valve cover (for about 2 1/2 months) with no probs, although I eventually went with black for that. Technically, the MetalCast isn't high-temp spray paint, so I would like to add that I did use a final coat of high-temp clear on top of the red for the valve cover....but none on the intake, and like I said before, I haven't had any probs with it at all. I'll see if I can track down a digicam and take some pics for you. Hope this helps.
Steven T
12-05-2007 09:24 AM
dblclutchin
12
06-07-2007 08:39 PM
strtballer98
05-20-2007 09:39 PM
cderalow
05-04-2007 11:26 PM
