Fueling/ SR vs. CAI
Old 06-07-2006 | 06:45 PM
pWnEdU's Avatar
Default Fueling/ SR vs. CAI
Does the stock ECU and injectors have the capability to compensate for I/H/E or is reprogramming necessary?
Also, is it true that a short ram intake gives more torque than a CAI? These things have no torque to speak of so I think I may get the short ram... not to mention it looks like they're cheaper. Thoughts? Upon reviweing AEM's website, it looks like the SRM is superior in low end torque.
Old 06-07-2006 | 09:16 PM
Clean98EX's Avatar
Default RE: Fueling/ SR vs. CAI
there isn't really a problem with the ecu having to be programmed. not with just I/H/E, if it was programmed you might make more because the tune. yes it is true that these engines have little torque but the torque they make is all above 5000rpm. not low end at all. get the CAI and be done with it. SRI's suck and won't get the nice cool air. or get a two piece one and try both.
Old 06-07-2006 | 09:23 PM
Street Sniper's Avatar
Yes, the stock ecu program can compenstae for bolt-ons. Also the stock injectors are good to about 160Hp. And on a final note, there is virtually zero difference in max Hp between a CAI vs. SRI.
Old 06-07-2006 | 09:40 PM
pWnEdU's Avatar
That's what I thought... from AEM dyno sheets, the max HP gain is similair, but low end torque is higher with SRM while low end power is LESS with CAI...
I ussualy drive 2000-4000 rpm's, and that's where the power is at with the SRS.
But maybe my logic is all off.
Old 06-07-2006 | 09:46 PM
pWnEdU's Avatar
What is stock FWHP (not crank) for my car?
What's the ballpark it would be at with a 4-2-1/srs/greddy EVO2 combo?
Old 06-08-2006 | 01:20 PM
ORIGINAL: pWnEdU
Congrats, you are the 1millionth person to ask that question
sorry, felt like being an *** for a minute, CLICK HERE!
Old 06-08-2006 | 05:32 PM
pWnEdU's Avatar
Sorry I had to be another guy who doesn't search enough...
Old 06-09-2006 | 07:29 PM
pWnEdU's Avatar
So at a given speed, my fuel mileage should probably increase with these mods, correct?
NOWAYTREY
10-21-2011 08:05 PM
mysi
08-10-2007 07:51 PM
pWnEdU
06-14-2006 05:28 PM
killasystems
06-10-2006 05:30 PM
turbo t
06-10-2006 12:05 AM
