Could I use this as a resonator?
RE: Could I use this as a resonator?
ORIGINAL: Nail I3unny
glass? melting out? hahaha. did you know what glass is? its melted and shaped sand. ever tried melting sand? doesnt work to well. thats what a lot of FDs use to put out forest fires.
ORIGINAL: finalimpact
i use cherry bombs as resonators. but i also use a muffler after that. ive had no problems out of my exh systems at all while using cherry bomb glass packs. your exh sounds to be the same as mine. header, no cat, im using a 16" cherry bomb, and a magnaflow muffler. with this i get very little rasp and a nice tone.
Would it hurt anything if I ran dual resonators?
I would say that the cherry bomb and the Red hot are the exact same thing just listed under different names for marketing. You could run 2 but i dont thing it will help much i would run a long glass pac and get a good muffler like a HKS or something of that nature and it will help with raspyness. You will still get some at high RPM's because its a honda. Also leave the cat in of go with a high flow cat it will also help with getting rid of the raspyness. Good luck.
Steel wool burns which you wouldn't ussualy believe, but because it's so thin, it does. Anything with carbon in it will burn (the process is the reaction between carbon and oxygen), just at different temperatures.
ORIGINAL: mxs
well, it does melt, just at really really high temperatures. I hope your EGT's are not that high...
ps. carbon doesnt burn...well...not well. when you burn wood or a plant or something, everything gets burned away EXCEPT the carbon...thats the ash thats left after combustion. try burning a pencil. whats left? ash and graphite. whats graphite? carbon. try burning a diamond. fat chance. whats a diamond made out of? carbon.
but yes steel wool does burn just because its so fine.
ORIGINAL: Kahuna
Is it really loud? I don't want something that is really loud inside the car. I suppose Cherry Bombs are made the same as the Red Hot I posted in the link. I want no rasp, and a nice deep tone under accel, but just a soft pur at cruising speed.
as far as glasspacks melting down, i wouldnt know i have yet to experience this problem.
You could probably just go to your local auto parts store and get a cheap glasspack for $20. That's about the same as the ebay one after shipping, but you get instant gratification.
If you use it instead of a resonator, in addition to another muffler, it will probably be quieter than if you use a resonator.
cheap glasspacks sound like ***. cheap anything sounds like ***. they dont act like resonators...just sound dampeners...and they only change the pitch. keep your eyes out for a good, high quality something.
