burning smell from Apexi WS2 exhaust
I just installed an Apexi WS2 exhaust on my 95 EX yesterday. I double-checked the connections & tightness, & it sounds great, but I'm noticing a pretty strong burning smell. I did have to take off the catalytic converter so I could access that top bolt (the heat shield was in the way). Is this normal for a new exhaust, or is it maybe the catalytic converter? Or something else?
Thanks
Thanks
It didn't look like the pipes were touching anything they weren't supposed to be, but I'll double check. The tail pipe has got a little less than 1/2" spacing between it & the bumper, so that's ok.
I did put the cat back on. I couldn't get the existing exhaust pipe off that was attached to the rear of the cat because of that 3rd bolt at the top of the flange, so I disconnected the cat from the exhaust manifold. After pulling that whole section of pipe & cat out, I was able to disconnect the cat & then I reinstalled it with the new exhaust system.
^^^Agreed, sometimes, depending on what polish is used, or any other coating, it could just be that burning off creating the smell. My friend installed his Apexi N1 the other day and had a similar smell. I had a smell after installing my GReddy EVO2 Catback
