Bosch Platinum +4 problems?
Old 06-09-2005 | 12:52 AM
JDMracer00's Avatar
Default Bosch Platinum +4 problems?
I just heard that the platinum 4's can make you run to hot from a reply in one of my other posts...has anyone else ever heard of this problem? I have the plat +4's...please help
Old 06-09-2005 | 01:10 AM
315 Customs's Avatar
Default RE: Bosch Platinum +4 problems?
i used to run +4's in my built 97 cavalier z24 that ran low 14s, never had a problem.
my buddy runs +4's in his built LS motor w/ MSD also running low 14s, alos no problems
Old 06-09-2005 | 01:25 AM
JDMracer00's Avatar
also..which would be better to get...Iridium or Platinum? That's prolly a dumb question but I don't know much about ignition stuff at all. Thanks
Old 06-09-2005 | 02:03 AM
D16z6's Avatar
my brother is running it right now on his 88 Porsche 924s and so far no problem.
Old 06-11-2005 | 01:44 AM
Kappa22's Avatar
I'd stay away from +4's on a high-comp. engine (I.E. a Honda...) especially if you're modding. They do have a tendency to run too hot, and they burn themselves up quite frequently. Stick with the +2's. And as for platinum vs. iridium, iridiums fire colder, but plats fire bigger. I'm a fan of the iridiums myself... NGK or Bosch.
Old 06-11-2005 | 01:36 PM
sacicons's Avatar
also, for nitrous, i personally like the good old copper plugs(one or two heat ranges colder than stock). not for a performance effect, but the tips on the plats and the iridiums are so small that the insane cylinder temps you hit on the bottle will burn through them over a fairly short period of time. and replacing those expensive iridiums every 10-15k is a bit outrageous.
Love2drive
07-06-2011 06:25 AM
STREETFIGHTER50
04-28-2008 01:08 AM
CivicRights
04-20-2006 06:33 PM
CivicRights
04-20-2006 01:41 AM
riceburner700
03-23-2006 06:36 PM
