KingDakota12's 99 Civic DX Build
Oh man noob is confused!? There are subframe braces which hold sway bars together I think and there is a lower arm bar.
Which do I need with my LCA's if any? Remember cheapest, but smartest.
Not sure what you need an explanation on....
Id like to go just for looks and the drop right now because no need to sway bars with a d16y7 as of right now, so If I could get away with coilovers, LCA's and a subframe brace will that be OK?
I am not sure why you dont get this. There is no point in a subframe brace unless you have a bigger than 13-14mm sway bar being installed. If you just want looks, then by all means, go for it, but it will be pointless. You can take that $200 spent on a brace and get a lifetime alignment plan from a local auto shop.
Sway bars have nothing to do with the motor. It helps with handling.. alot. A sway bar would make the car alot more fun to drive IMO.
If you want just the look, coilovers, LCAs, and an alignment plan and you are set.
But I do understand what you mean man the If I got an aftermarket sway bar then I would get a brace and I understand the Camber as well, but I just want a drop so all 3 items you listed above are what Ill get.
Thanks for the input though man it helps!
So If I did get a rear sway bar and end links would this be a good combo?
http://www.jhpusa.com/store/pc/viewP...ry=291#details
http://www.jhpusa.com/store/pc/viewP...idcategory=169
But still not sure on the right subframe brace to buy and if I bought a subframe brace witht the items above would I need an after market lower arm bar?
How about this as an entire suspension upgrade?:
http://www.jhpusa.com/store/pc/viewP...idproduct=3836
http://www.jhpusa.com/store/pc/viewP...idcategory=256
http://www.jhpusa.com/store/pc/viewP...idcategory=357
http://www.jhpusa.com/store/pc/viewP...idproduct=1908
http://www.jhpusa.com/store/pc/viewP...idproduct=2520
With this combo would I need a lower arm bar as well or no?
