Flip's Turbo Project, Read Page 44 For Some Info!
#253
RE: Well here goes nothing
on the greddy turbo timer, i actually put one in a subaru wrx sti the other day and there are only 6 wires that need to be hooked up. a 12v, acc, ign, and ground,then e-brake, and speed sensor. the civic doesnt have a speed sensor wire, and the e-brake is optional but recommended. if you get the harness, it goes in line with the ignition harness so none of those wires have to be cut, soits reallyeasy.so i doesnt matter what computer you have, cuz the ignition harnesses are all the same
#254
thanks sooo much sig racer
anyone else on teh charge piping? I'm thinking like one J-pipe (to loop around under the washer fluid reservoir), a few straight pipes, a 45 to bring hte piping up after the FMIC, then another straight one?
and again, oil line? Thats the one i have no idea about.....
#255
so i need to weld my BOV flange to my charge piping, and also need to weld my oil pan tap to the pan itself. It's all aluminum and i cant find anyone to weld it for me. How did all you guys go about getting your aluminum stuff welded??
#257
ORIGINAL: FlipHKD720
#258
ORIGINAL: Mr Mobsta Man
You have a y7 don't you? I thought the pan for your engine was steel.
but still, BOV plate onto charge piping?? Can you just use a MIG or TIG welder or do you need a special welder?
