Windshield frosted up on the inside
Old 01-20-2008 | 09:40 PM
FlipHKD720's Avatar
Default Windshield frosted up on the inside
So up here in Michigan for the last 4 or 5 days, it has literally been -10 to -20, before windchill. Needless to say its been unbearably cold and you can barely stand outside, even when bundled up wiht 3 to 4 layers, hats and gloves. Anyway, whenever i get into my car, my windshield is ALWAYS iced up on the inside. Sometimes there's hardly any frost on the outside, it's all on the inside. What is this from? I don't care if its a dumb/noob question. What can i do to stop this? I have to start my car 15-20 minutes early every time i want to go somewhere. I have a crack in my windshield thats getting bigger and bigger...does that have anything to do with it?
Old 01-20-2008 | 11:58 PM
Gene J's Avatar
Default RE: Windshield frosted up on the inside
In northern Illinois we run into the same problem. You need to dry out the inside of the car and keep it dry. Not too easy this time of year. Every time you get into the car your shoes track in snow or water. When you breathe inside the caryou exhale moisture too. It's worse when you carry passengers, because you get even more moisture. When the car cools off all the moisture has to condense somewhere, and since the windows cool fastest, it collects there as ice.
Luckily I have an attached garage that seldom goes below freezing.
Old 01-21-2008 | 10:50 AM
FlipHKD720's Avatar
and i'm parked in the freshman lot AKA frozen tundra [:@]
well does the crack in the windshield make any difference? (thanks gene )
Old 01-21-2008 | 11:15 AM
Firehawk989's Avatar
I don't think the crack will allow any extra moist air in, or make the ice worse, but the crack will keep spreading with the heating/cooling cycles you're putting the windshield through every time you drive your car and then park it and it cools off. I had a pretty big rock chip in the windshield of my Suzuki; it started as a little star shaped kind of chip, and then the next morning I started it up and as it was warming up a crack spread from the chip all the way across the entire windshield. Luckily it was across the bottom of the windshield and out of my field of view.
Old 01-21-2008 | 11:21 AM
FlipHKD720's Avatar
yeah this crack is RIGHT in front of my face and has gotten considerably bigger this winter, it sucks. Idk, thanks though you guys
Old 01-21-2008 | 11:36 AM
GReddy_Civic's Avatar
Snail'n Admin
get the crack fixed before it gets worse. insurance should cover it
Old 01-21-2008 | 11:40 AM
My04Civic's Avatar
Administrator
crack kills
yessum, get that crack fixed...your car is taking in moisture.
Old 01-21-2008 | 12:21 PM
well i dont think id get the windshield replaced till spring personaly.....
the glue will dry beter and just make a beter seal at the warmer temps.....
plus if your state uses some salt all the extra debri geting flung up TINKING off the windshield.... just a MAYBE so i would just wait IMO...
Old 01-21-2008 | 01:15 PM
StifflersMom's Avatar
Cat Fuсker
have you tried leaving the window down a little? Just down enough to ventilate?
Old 01-21-2008 | 01:17 PM
s0ulj3r's Avatar
ORIGINAL: My04Civic
crack kills
or is producing moisture.. this recently happened to me and it turns out it was my heatercore.. mine was a smaller leak and since i put some radiator stop leak in it is defenitly a HUGE difference.. also clean your car very well (sometimes theres stuff under the seat that might be producing moisture (aka damp something or other from the snow)
