What do i do about my car bogging down?
Old 10-06-2008 | 04:22 PM
gtmci84s's Avatar
Default What do i do about my car bogging down?
I Have an 89 Civic DX Hatchback. Its got a 1.5 5 sp dpfi. The car is pretty much stock. Has about 190,000 mikes on it. I took it on about a 100 mile drive last weekend all highway runs really good on flat and down hill but as soon as i get to any incline at all it boggs down and doesnt want to go over 60 mph, it doesnt do this all the time only after i have been on the road for about a half hour. I mean its a verry strong running car so i dont really understand it. If i go about 20 mins away on the highway it goes up inclines fine, but about 25 miles into the drive going further it will start bogging down on the slightest of inclines. Any thing i can do not too major to fix this problem at all? Thanks.
Old 10-08-2008 | 11:18 AM
Starjumper7's Avatar
If it had a carb I would say it was a weak fuel pump, but those don't have carbs, do they?
Old 10-08-2008 | 12:20 PM
This is a DPFI, or throttle body injection system that was used from 1988 to 1991. Weak fuel pump will do similar things on a fuel injected car too. Try changing the fuel filter first. If it "boggs" or misfires every time in normal acceleration it could also be the ignition.
Does the check engine light come on? Do you have any codes flashing on the ECU light? You need to look at the ECU itself, which is under the carpet where the passenger's feet would be. There is a single red LED behind a window. Turn the key on but don't start the car. The light may flash a number of times, pause, then flash again. Count the number of flashes between pauses.
Old 10-08-2008 | 01:28 PM
As mentioned, try a basic tune up (plugs, wires, cap, and rotor) and also replace the fuel filter.
Old 10-08-2008 | 07:41 PM
sittinSideways's Avatar
Yea, start with getting some new OEM sparkplugs.
Old 10-11-2008 | 01:06 AM
whtrastaman's Avatar
i had a similer problem on my old civic it was the fuel pump it had a bunch of garbage from the tank stuck to it............ so try the fuel filter frist then try the fuel pump
Old 10-11-2008 | 11:48 AM
Sounds like weak fuel pump.
Think about it, you're going up a hill, so the gas in the tank moves towards the back of the tank, further away from the fuel pump. With a weak fuel pump, pumping this gas at the normal rate would be difficult.
jprommel
17
10-09-2008 12:16 AM
SITNLOW97
12-05-2007 04:22 PM
Garon
15
10-06-2007 04:10 PM
Workman
05-24-2007 06:55 AM
dfdon
05-20-2007 07:51 AM
