squeking and aircon problem need help
Old 07-04-2010 | 07:12 AM
maroon's Avatar
Default squeking and aircon problem need help
got two problem about my civic 00 im trying to resolve right now and need some advice from the best guys here in the forum,
1. about 1 month ago i replaced my REAR LCA,camber kit,and trailing arm (skunk2 and genuine honda parts for the trailing arm)
after a month im hearing some sounds like squeking in the rear for almost 1 week nowand its , im thinking of putting some oil loosen the nuts and rubber is there any negative effect if im gonna put oil on the bushing of the LCA and Camber?
2.put freon on muy car yesterday and i thing i overloaded it,now when im using my aircon my car i like having hard time breathing,is that a sign of overload of freon ? is there anyway to underload the freon?
thanks and HAppy 4th of July guys!!!!!!
Old 07-04-2010 | 03:43 PM
SPLAT's Avatar
The A/C prob, not to sure about.
But squeking in the rear of your car could be a bad bearing.
Old 07-05-2010 | 07:58 AM
Overcharging the A/C will not cause a problem with interior air quality, unless there is a severe leak inside. In that case the refrigerant would all leak out in a matter of minutes to hours and stop working again.
Refrigerant is not normally a consumable item, a need for periodic recharging means there is a leak which should be repaired. Do not try to use "stop leak" products, they don't work and will lead to major problems.
Kyle_2015
03-29-2015 12:49 PM
classiccarsrule85
04-25-2008 09:58 AM
maroon
04-17-2008 04:24 AM
dk101ex
07-05-2007 03:21 PM
frech88
05-21-2007 04:38 PM
