rubber strips in wheel wells
ok i've heard this from a couple people and thought i'd run it by you guys...there's rubber strips that run on the inside of the wheel wells, i've been told that water gets caught between them and the fender/quarter, causing eventual rust. is this true?
RE: rubber strips in wheel wells
i suppose a small amount of water could get stuck in there, but removing those parts would let all kinds of crud flick up inside the wheel arch, such as wet mud, stones n such, which could also cause damage
they are not needed, unless you're driving in pit gravel at high speeds, you'll be fine, and yes it does cause rust because of mud and wet debris gets caught between the body and the strip. i'm glad you mentioned that, i've been meaning to do that and just kept forgeting. mine are really worn and keep slipping off at the edges.
ya anything pre what... 92 is a rust bucket if around salt... only cali and texas rust frees. LMFAO
i still have to pull all mine and check for any rusty areas... then im gonna POR the rusty spots... paint over rust is what the initials mean. ive heard that stuff works great..
TSR96civic
15
08-19-2007 08:58 PM
ufcebuano
06-20-2007 06:11 PM
