redlining
RE: redlining
When u race yeah u shift late. and u really use about 2 gears which is 1st and 2nd and maybe 3rd but that depend on the distance butu usually use1st and 2nd gear the most. and yeah its bad casue it casue a lot of strain on the engine/transmission
RE: redlining
here is an example of what your cars motor is doing when you are driving and an occasional redline occurs... take a paper clip (a good thick one) undo it to where it is straight... now bend it back and forth slightly like you are shifting normally...(it will bend back and forth slightly for a long *** time)... now bend it to where ends meet (like redline) after so many it will break... its the same problem w/ motors. i hope that might have helped but i am a little confused on my explaination lol
RE: redlining
ORIGINAL: phsballer123
Anyway, does your car have a rev-limiter? If so, for the most part, it's safe to hit the limiter (as opposed to going past redline) every once in a while. Usually the limiters are placed way before indicated redline (on my z6, the limit's around 6600, but the indicated redline's 7200). But don't do it every chance you get; like everyone else has said, the higher the rpms, the more wear on your engine.
RE: redlining
As long as youve got oil in there it aint too bad. Hondas are high revving engines, sometimes when I get on it I take it as high as 9,000RPMS. Like I said, hondas are meant to rev high, so its not like youre going to blow your motor up if you hit the red every so often.
RE: redlining
The D15B7 has a redline at 6500 RPM and a rev limiter at about 7000 RPM. The engine can rev much higher, as long as it's balanced and the valvetrain can handle it. Usually the redline is so low because going higher there is usually a problem with vibration in the Honda engine. Also, power drops off at the redline anyway, so when you hit it you upshift. Really, though, you may not even need to stretch it into the redline if the power drops off before hitting the redline. I remember hitting 6500 RPM all the time when I had my Civic (it was an automatic), and the engine didn't have a problem with it. Just remember that the engine will wear exponentially faster when you push it that last 1000 RPMs before the red.
http://www.youtube.com/watch?v=Rl8T9KFgjWc shows what a Honda B Series can do when you eliminate vibration, and what happens when you take a factory engine past the rev limiter.
