p1259 code
It will say "VTEC" in big letters on the valve cover if it is. On the VTEC engine there is a solenoid and pressure switch on the back (intake side) of the head near cylinder #4. If someone has replaced the engine with a non-VTEC one there might still be wires there that don't go anywhere now. Or they could have swapped the engine harness too, it usually comes with a used engine when you buy one.
After the CEL has tripped on, the ECU will operate in "limp home" mode which reduces some performance aspects. The engine will not rev above 5000 rpm. It may also affect the shifting of the automatic.
well all civic in that year came with a basic 1.6. the only difference was the vtec. did you valve cover say vtec on it. if not then yes, you will need a new ecu. which is p2e. but first check if your engine is vtec or not.
