Need the Part Numbers for my Car
2001 Civic EX Coupe is my car need the part numbers that i'm missing.
Ok i'm gonna be buying the parts for the timing belt online and i wanna make sure i'm not missing anything. I also need a few other parts aswell so if i'm missing anything please feel free to add to the list, i don't wanna miss anything. Ok here goes..
Parts needed:
Timing Belt - done
Tensioner - done
Water Pump - done
Crankshaft Seal - not Sure if i got the right one
Camshaft Seal - not sure if i got th right one
Valve Cover Gasket - missing
Oil Pan Gasket - missing
Front Motor Mount or Entire Motor Mount Kit - not sure about this one
Compliance Bushings - done
PCV Valve - done
A/C Belt - missing
Alternator Belt - missing
Ok the guy at Advance Auto Parts recommended i change the thermostat and the thermostat seal, should i do it? Again if i'm missing anything please feel free to add.
Parts needed:
Timing Belt - done
Tensioner - done
Water Pump - done
PCV Valve - done
A/C Belt - missing
+1, good place to buy from.
I found most of the part numbers i need. However there are a few i'm not sure about or have trouble finding. That's why i'm asking for help. The mounts, seals and gaskets are the ones that are giving trouble. I'm not sure as to the mounts as i saw 2 mount parts and i don't wanna pick the wrong one.
edit: haha thanks guys http://www.hondaautomotiveparts.com/
is actually 16 cents cheaper than hondapartsnow.com which was the first one i found. guess i'll be using that site if it's the cheapest one out of the bunch when i have all the parts.
Now if you guys can help me get the above mentioned parts so i don't end up with the one part.
Oh yeah see i can't find my drive belts, a.k.a A/C and Alternator Belt on any diagrams. This is why i need help finding everything i need. I think their called Serpentine Belts in my car but i still can't find them.
Timing Belt - 14400-PMM-A02 BELT, TIMING (104RU22 GB-333) $18.43
Tensioner - 04145-PLC-315 TENSIONER SET, TIMING BELT $80.81
Water Pump - 19200-PLM-A01 WATER PUMP $81.00
Crankshaft Seal - 91212-PLM-A01 OIL SEAL (38X50X7) (YAMADA) $4.23
Camshaft Seal - 91213-P2F-A01 OIL SEAL (29X45X8) $3.47
Valve Cover Gasket - 12030-PLC-010 GASKET SET, HEAD COVER $29.27 (includes spark plug tube seals and the washer seals for the bolts)
Oil Pan Gasket - there isn't one you use HONDA ULTRA FLANGE II SEALANT OEM PART # 08718-0009
50840-S5A-A81 STOPPER, FR. ENGINE (AT) $38.53 (front w/AT)***
50810-S5A-992 RUBBER, RR. ENGINE MOUNTING $31.37 (rear w/AT) ***
50820-S5A-013 RUBBER ASSY., ENGINE SIDE MOUNTING $67.50 (driver's side w/AT AND MT) ***
50840-S5A-010 STOPPER, FR. ENGINE $47.57 (front w/MT)
50810-S5A-013 RUBBER, RR. ENGINE MOUNTING $33.72 (rear w/MT) ***
ARE YOU SURE YOU EVEN NEED MOTOR MOUNTS?
Compliance Bushings - ???
PCV Valve - 17130-PLM-A01 VALVE ASSY., PCV $16.96
A/C Belt - 38920-PME-T01 BELT, COMPRESSOR $13.89
Alternator Belt - will get part# Tues
P/S belt - 56992-PLM-003 BELT, POWER STEERING PUMP (BANDO) $8.56
Well Honda and Firestone said i do need a new front motor mount but i can tell as the engine does jump alot when i put it in drive from neutral. I'm gonna double check tommorrow with my dad that way we get an idea of how to do it ourself as save on labor.
I'm bascially doing everything myself minus the timing belt job. the labor for the timing belt is $167 so for about $400 i get all the parts i need and get the timing belt done and that's it my car is done and nothing else needs to be fixed.
So were you able to get the part number for the alternator belt?
Also anyone want to comment on weither i should get the thermostat and thermostat seal?
I need somehelp as i need to order the parts so hopefully i can do the work by the weekend if they get here on time.
