Leaking oil pan
Old 11-29-2010 | 07:21 PM
mikeybson's Avatar
Default Leaking oil pan
i have a 93 civic. my oil pan is leaking about a half quart of oil every 2 weeks. the threading for my oil drain plug is shot so i had to use a universal plug which isn't doing the trick obviously. im planning on swapping the entire oil pan out. i have a couple questions before i start... how big of a project will this be? how much should i expect to spend? would it be cheaper to try to just re-threaded the hole?
Old 11-29-2010 | 08:05 PM
TiggerDX's Avatar
My oil pan was $110 and the gasket was $15. It's a fairly easy job. Pull the exhaust from the bottom of the manifold to the cat. 7 bolts total. Then the plate on the tranny over the fly wheel. 4 bolts.
Then undo the oil pan.
If you want to save money, order a Quick Oil Drain Valve
Not sure what size you would want since the hole is stripped out, but once it's in there, you never have to remove it.
Old 11-29-2010 | 08:11 PM
mikeybson's Avatar
would the oil drian valve be able to screw into my oil pan since the threading is no good?
Old 11-29-2010 | 08:21 PM
civicexracer's Avatar
I'd suggest looking around online for some used oilpans or maybe hit up the junk yard, much cheaper than buying a new one and should be just fine. Just make sure they aren't dented/cracked and the drain plug is ok.
To do the job isn't all that hard but a little time consuming. Drain the oil, remove the exhaust, unbolt the like 15 little bolts holding the pan up, then tap the pan a few times on each side with a soft faced mallet to knock it off. You'll then want a gasket scraper or razor or something sharp that will get the old gasket pieces off of the block and also the oil pan if you replace it with a used one. This can be a bit of a hassle but just be patient and make sure they are very smooth and clean. Put the new gasket with a little bit of oil on it(to ensure a good seal) and install it making sure it's snug all around. Then bolt it up and maybe put a little gasket sealant on some parts to ensure a leak-free pan.
Old 11-29-2010 | 09:31 PM
TiggerDX's Avatar
You might have to buy a slightly larger size and tap your threads for the new size.
Old 12-01-2010 | 02:31 PM
1992 civic driver's Avatar
very easy job to replace the oil pan. get a Haynes Manuel if you dont think you can do without it
RonJ
04-28-2011 12:56 PM
beagler
12-07-2010 05:44 AM
ic892003
20
08-21-2008 04:40 PM
oilltd
06-10-2008 05:06 PM
