can you run boost on standard ecu map
Old 11-19-2006 | 03:59 PM
tombakers's Avatar
Default can you run boost on standard ecu map
can i run boost on base map safely on my b16a2?? i have a vafc2 apexi system which i will have tuned on the rollers. but can i drive the car with the turbo kit on for a while safely or should i get a boost dependant regulator to be safe?. can anyone HELP!!
Old 11-19-2006 | 04:13 PM
riceburner700's Avatar
Default RE: can you run boost on standard ecu map
yes you can run boost i think up to 11psi without the cel coming on. you can only add so much fuel or subract so much before that will also trick the cel
Old 11-19-2006 | 04:24 PM
tombakers's Avatar
thanks for the help. what is cel?? will the engine not be running lean and cause problems on basemap ie pinking etc?? there will be much more air but no more fuel! is that right?
Old 11-19-2006 | 04:51 PM
Mr Mobsta Man's Avatar
cel= check engine light
Old 11-19-2006 | 06:10 PM
t34me's Avatar
ORIGINAL: riceburner700
I dont know if thats entirely safe. Basemaps are just that, the very base program necessary for the motor to run. Youd be safer running 11psi on a stock non modified ECU than a chipped one with a basemap on it. But, again im no expert. Personally, i would just wait till its tuned to get on it like that.
Old 11-20-2006 | 12:41 AM
gotboost?'s Avatar
yea if your really worried, run low boost until you can take the steps for proper mapping. I agree with the other guys.
Old 11-20-2006 | 08:26 AM
running boost without a suitable tune is stupid, period
Old 11-20-2006 | 01:03 PM
Fiirkan's Avatar
Forty's Wisdom FTW!! lol
Old 11-20-2006 | 01:27 PM
ORIGINAL: Fiirkan
I fell that it's best served in the form of blunt force trauma
Old 11-20-2006 | 01:49 PM
Fiirkan's Avatar
^ I'll get the 2X4 you get the bats... should we get a brick too? or would those be blunt enough?
