Can a 90 dx rear crossmember go in a 91 si?
URGENT!!!!my car as said in other posts was in a little accident and the front and rear crossmembers near where the motor sits are bent, so can i pull those from a 1990 dx? thanks guys please response, in a time crunch
Go to hondapartdeals.com, search under 90 DX, find crossmember(s) and write down part number.
Then search 91 SI, find crossmember(s), and compared part numbers. If the middle 5 digits are the same, it is pretty much safe to assume that they are the same part.
ok thanks you cv, i looked and it doesnt even have crossmember under the search, since i have a 90 bumber on my car im sure a manual non power steering 90 dx front and rear cross member will work
theRDRman
12-13-2011 10:52 AM
