automatic transmission fluid change
Old 04-27-2010 | 10:11 PM
mikeybson's Avatar
Default automatic transmission fluid change
so is it simple to change your automatic transmission fluid and the filter as well? is it basically the same as an oil change?
Old 04-27-2010 | 10:56 PM
transmission fluid yes, filter no
the filter is an internal filter and in order for it to be changed trans has to be dropped and split,
just change the fluid
Old 04-29-2010 | 05:10 PM
Winngrip's Avatar
Default ATF-Z1 fluid
Does anyone have a good reasonably priced source of ATF-Z1?
thanks
mike
Old 05-01-2010 | 07:14 PM
waterman71's Avatar
My mechanic sells it for about 7.00/qt out the door. Dealership was about 50 cents more.
Old 05-01-2010 | 07:50 PM
Yea, dealership is already pretty cheap for transmission fluid. Sometimes you can find a good deal on eBay too, but usually the dealer will be cheaper.
Old 05-02-2010 | 08:24 PM
Winngrip's Avatar
Default tx fluid
thanks for that good info guys
enigma34
05-13-2009 07:41 PM
jetspeedz
09-10-2008 10:56 PM
iwishiwasemo89
16
07-27-2007 01:27 PM
iwishiwasemo89
07-27-2007 01:07 PM
Toppers
02-02-2006 02:30 PM
