whats the best?
Old 05-14-2005 | 05:34 PM
sacicons's Avatar
Default RE: whats the best?
forget the awd. the only real choices of parts you have, are from a CRV, and are not made for performance, so they dont hold up under heavy loads. let alone most of it being custom, and expensive. K20 is a good idea, but VERY expensive, and yes, you can do the 6-speed. but easiest choice would be the B18c1, GSR. unless you plan on going all-out, as in full sleeves and a custom build, then you can save a bit of money and start with an LS block, then add a vtec head once its built. also, a b16a head on a gsr block will drop the compression a bit, and flow better than the gsr head, so thats a great choice for turbo.
Old 05-14-2005 | 08:05 PM
Nail I3unny's Avatar
ORIGINAL: sacicons
to throw a number out on the table i believe se7en said his turbo k20 setup (not including the rebuild price) was something like 8 grand
Kleanride
06-14-2007 04:00 PM
Standuphonda
04-26-2005 08:58 AM
cool chris
04-21-2005 09:33 PM
maddstylez
EG Swaps
12-31-2004 01:30 AM
aztecpimp
08-04-2004 04:47 PM
Quick Reply: whats the best?
