What is the H.P. limit for stock axles?
Old 12-19-2008 | 12:54 PM
MTC's Avatar
MTC
Default What is the H.P. limit for stock axles?
I should be at about 250hp to 300hp.
Old 12-19-2008 | 12:59 PM
xsteinbachx's Avatar
Are you asking a question? or answering your own question? if so why did you post?
Old 12-19-2008 | 01:57 PM
ej6buddy's Avatar
If you give me the material and shaft size and manufacturer process, then I can tell you an exact hp limit that the axles can withstand (ones of the perks of engineering ). But the main problem is the gear and joints.
Old 12-19-2008 | 06:37 PM
315 Customs's Avatar
I have seen stock B series axles handle up around 350whp for quite a few passes using 2 step
Old 12-19-2008 | 07:08 PM
ej6buddy's Avatar
It also depends on how much the car is lowered, which can lead to failure due to joint binding.
Old 12-20-2008 | 08:18 AM
riceburner700's Avatar
its really up to how you drive the car. we have ran 10.89's on stock axles, with over 640hp 434 ft lb. never had a issue with braking a single factory axle
Old 12-20-2008 | 06:17 PM
MTC's Avatar
MTC
I will check the axle size when I go back to work on monday. But the axles are for an Acura LS trans mated to a B16A.
Old 12-20-2008 | 06:21 PM
ej6buddy's Avatar
I was just kidding man, It all depends on how you drive the car. Are you planning on ripping it and ******* it all the time? If not, then you should be fine. Honda motors aren't torquey enough to snap them most of the time.
Old 12-20-2008 | 07:51 PM
bcrichguitars's Avatar
So being lowered with lots of hp=better chance of breaking axle?
Old 12-20-2008 | 07:59 PM
ej6buddy's Avatar
The axles and placement of the axles are designed by honda to withstand the most load at those initial suspension geometries. Of course you have to take into consideration that your suspension also has free motion, but it's mainly designed for factory suspension specs. With your car and setup, I wouldn't worry about anything.
tombakers
05-04-2008 06:23 AM
addiction2bass
12-27-2006 09:38 PM
Carlz0r
11-28-2006 07:13 PM
megafandrew
14
09-02-2006 11:48 PM
civicnut33
10-13-2005 07:47 AM
