TYPE R PISTON IN TO B18A BLOCK?
RE: TYPE R PISTON IN TO B18A BLOCK?
as far as i know, they will fit, but, check into the compression. also, dont do this if you are planning on using the ls head, i assume this is for the ls vtec project youve been asking about, if so then go for it, but the valve pockets in the type r pistons are located wrong for a non-vtec head and they will hit the valves. if you are using the vtec head, then it should be okay.
I know compression will be bumped up. but to what, I don't know.
the ITR c5s stroke is 87.2 mm and the A1 block has a stroke of 89 mm. There's a calculator out there somewhere but it's inaccurate at best.
JDMB16CIVIC
11-30-2005 09:51 AM
JDMB16CIVIC
08-11-2004 08:29 PM
JDMB16CIVIC
08-11-2004 08:29 PM
