timing belt and water pump
Old 09-17-2006 | 03:12 PM
POLYTHING's Avatar
Default timing belt and water pump
hey guys, my bud has a 94 integra....just installed a timing belt and water pump...the engine turned on normal and ran for about 5 min. Suddenly, it shut off by itself, and would not start again...wat happened???
when we try to start it again, looking through the oil cap, the Cams are spinining; battery is good...the mechanic told me there s no spark to the sparkplugs!!!
it s been 2 days guys. someone help!!!!
we dont know wat to do...[X(][:@]
[IMG]local://upfiles/11910/7A333277EFB74D95A0866270148555D0.jpg[/IMG]
Old 09-17-2006 | 04:12 PM
HARI.'s Avatar
Default RE: timing belt and water pump
1.check if the belt is tight. probably the tensioner somehow got loose.
2.make sure the timing mark is @TDC. maybe it skipped a tooth or two
Old 09-17-2006 | 08:52 PM
POLYTHING's Avatar
i think the mechanic checked those.. even if number 1 and 2 happended, the cams should be rolling right?
Old 09-17-2006 | 11:57 PM
riceburner700's Avatar
damn you guys got oil on alot of things.... lol timing belt looks kicka$$ is that a stronger one than oem?
Old 09-18-2006 | 12:26 AM
POLYTHING's Avatar
100 buck ebay greddy timing belt... cant start.....
alin
01-26-2009 06:08 PM
dave_57204
01-27-2008 11:16 AM
SpeedRacer_87
07-29-2007 10:41 PM
LIhybrid
10-13-2005 04:04 PM
smokingemcee
08-09-2005 11:36 PM
