swapped internals
Old 11-29-2006 | 08:35 AM
Marty's Avatar
Default RE: swapped internals
LMFAO you need not give advice if it takes you 5 and a half hours to take a head off a D series. Use a Z6 block as the 96+ blocks have oiling issues.
Old 11-29-2006 | 09:12 AM
ORIGINAL: Marty
Good advice, but, if you do want to stick with the y8 block, the oiling issues are fairly easily resolved.
Old 11-29-2006 | 02:53 PM
Kedawei's Avatar
ORIGINAL: Forty04
ORIGINAL: Marty
Let me guess, besides several general methods to make an oiling systems more efficient, more specifically, widen the diameter of the rod bearing oil passages?
Old 11-29-2006 | 04:23 PM
BillyB98's Avatar
i really dont want my daily driver going up in smoke so are there any alternatives to make power than doing full on swaps? I have i/h/e but i would really like to get the internals done somehow without wrecking anything so is there anything i can upgrade or swap with out getting myself in to deep?
Old 11-29-2006 | 07:25 PM
Nail I3unny's Avatar
get an EX transmission, intake manifold, and a CAI made for an EX.
Old 11-29-2006 | 07:57 PM
Pete's Avatar
ORIGINAL: Marty
Seriously, its 10 bolts, slip off the T belt and youre good to go. (After intake and exhaust manis are off)
Old 11-29-2006 | 08:09 PM
BillyB98's Avatar
Ive been looking for a Y8 manifold and i plan on buying one when i find one. If i do that swap to the Y8 mani will anything else need to be swapped ecu, wires etc?
Old 11-29-2006 | 08:47 PM
Marty's Avatar
not if you use one from a 99/00 civic ex automatic
Edit--I am saying to use a 90/00 ex automatic manifold as everything bolts right on, no ecu changes need to be made, no sensors need to be altered. But a 96-00 ex manual transmission will give you the best gain at first. Then do a Intake manifold, and then if you plan on staying non-vtec with your head get in contact with delta cams and have them regrind a cam for your engine, use all Y8 vlave terrain(springs, valves, retainers, etc, etc).
Do that and get a excedy stg 1 oem replacement clutch, have your stock flywheel shaved to 13/14 pounds, get lightweight wheel like Rota's or some 92-95 civic vx rims or get some 96-00 civic hx rims.
All this can be done for around $1000 to $1300ish and you would have a very snappy/responsive setup and you will suprise alot with it trust me.
Old 12-02-2006 | 12:34 PM
BillyB98's Avatar
Im still trying to find the intake manifold and im going to hold off on the tranny swap until the summer. I would like to swap to vtec but how hard would it be and should i use the Y8 or the Z6 and will everything match up right? Should i have the flywheel shaved or just buy a differnt performance one?
Old 12-02-2006 | 01:43 PM
Remmy's Avatar
ORIGINAL: Marty
^ Agreed . My mech who has never touched a Honda managed to break apart my entire engine in under 5 hours.
skipdman
08-30-2005 12:11 AM
ballplaya4eva07
14
03-07-2005 09:06 AM
AgentofDarkness
01-23-2005 09:31 PM
ballplaya4eva07
12-10-2004 04:35 PM
AnakinKenobe
09-10-2004 08:28 PM
Quick Reply: swapped internals
