SOHC cam
Old 03-28-2006 | 02:36 PM
POIZN's Avatar
Default SOHC cam
Can anyone please tell me the advantages and disadvantage of installing a more agressive cam in a D16Y9 motor. SOHC non-Vtec head. I heard some stuff about losing low end power but better top end. I have to take into consideration its my everyday car and cant afford to change the engine. I know it wont be as fast as a DOHC Vtec, but how much will it differ?
Thanks in advance.
Old 03-28-2006 | 03:36 PM
Chimera02EX's Avatar
Default RE: SOHC cam
To really see gains from a more agressive cam you would need some fuel management as well, prolly even an EMS if you go stage 2 or above. Otherwise I'd say spend your money on something else.
Old 03-28-2006 | 07:34 PM
POIZN's Avatar
by installing a fuel/engine management unit, what would my gains be like? Before installing a cam.
Old 03-28-2006 | 07:37 PM
Big T's Avatar
^^^ I agree. But there are different types of cams that put put power in different rpm ranges. Stage 1, is for basically stock and mostly low-end power, stage 2 mid range, stage 3 high-end.
Old 03-28-2006 | 08:34 PM
jwsimons's Avatar
thats true for any power mod, your fuel map needs tuning whenever you install gainful power mods, especialy ones that will effect your redline, so saying its needed for one power mod like a cam is incorrect... to see the full potential of any mod you need tuning
ORIGINAL: Chimera02EX
Old 03-28-2006 | 08:36 PM
riceburner700's Avatar
hit the nail on the head^^^
Old 03-28-2006 | 08:39 PM
ef4life's Avatar
also with a cam, the idle quality can be negatively affected, which isn't good for a daily driver.
Old 03-28-2006 | 08:40 PM
jwsimons's Avatar
thank you, burner..(i wont call you rice on this forum, people will think im trying to **** you off!!!)
Old 03-28-2006 | 10:09 PM
Pete's Avatar
Installing a cam will become expensive......youd definetly wanna get a tune afterwards....making sure the fuel maps are made accordingly..........and tuning isnt cheap........neither is fuel management........have u looked into forced induction for your car? I can get ya a turbo kit for about a thousand bucks......
Old 03-29-2006 | 12:32 PM
POIZN's Avatar
Hey Pete, a grand for you guys is like 7 grand here in SA. Sure i can pick up a lil turbo with intercooler for that price but then the engine management costs another 2000 and then ive still gotta get someone to install dem tings. Im gonna end up with a 11 grand hole in my pocket.
Quick Reply: SOHC cam
