smoke when vtec kicks in?
RE: smoke when vtec kicks in?
ORIGINAL: BlackEM1
If it were the rings on your piston it would smoke 100% of the time.
ORIGINAL: Forty04
Thats not true at all. I've seen numerous cars with weak rings only smoke at WOT. Remmy's car did it before he had the built motor
ORIGINAL: BlackEM1
But, just because Remmy's car does one thing doesn't mean all engines will do the same. I still say it's the valve seals.
First of all is it really oil smoke? If the smoke is black that would be from running too rich. If it is burning oil you would also of course notice your oil level is dropping.
Bad rings do smoke worse the more you gas on it. I had a stock '91 with a D15B2 that wouldn't smoke at all at idle, but leave a huge cloud wide open.
You really don't know what the last guy did to it for the first 20,000 miles.
the smoke is kinda like gray/blue and yes my oil level drops a little when its not supposed to. i was told i was burning oil but i just dont know , i mean the car hasnt been tuned and im pretty sure its running rich but it can also be that my piston rings or valve seals are goingbad as you guys say. plus my fuel gauge sometimes reads 50 psi , when before it was always at 40 i dont know whats going on , its driving me crazy and on top of that i dont know whats wrong with the coolant level that keeps droping insanely fast. [:@]
ORIGINAL: BlackEM1
You don't have to be at WOT to activate vtec, but hey I got WOT before the vtec change over also.
ORIGINAL: Forty04
ORIGINAL: BlackEM1
I'm well aware of how vtec works as well, so save the condecending remarks.
ORIGINAL: Forty04
READ, I said I've seen numerous cars do it. I brought up Remmy's car because it was someone everyone knows, and it applies to the thread. Not to mention, just because YOU'VE seen valve seals fail once, doesn't mean that it happens to all motors.
ORIGINAL: BlackEM1
ORIGINAL: Forty04
ORIGINAL: BlackEM1
