Rebuild kit?
Old 01-26-2012 | 10:31 PM
fishdip1's Avatar
Default Rebuild kit?
Hey looking re build the engine on my 95 honda civic ex 1.6l vtec. Not looking to make more hp just looking for a rebuild kit that has all the stuff I need for this task. Any ideas on a good place to get this and what all to look for in a kit is greatly appreciated thanks.
Old 01-27-2012 | 07:44 AM
Re-build as in pulling out pistons, or simply replacing gaskets.
Old 01-27-2012 | 10:06 AM
fishdip1's Avatar
Thanks for the reply cvcrcr. It has four hundred thousand miles on it and leakes oil. So I will be pulling it and replaceing any parts that need it this will be the first time I do this so I have no idea what to look for in a kit or what to get But I will be taking it 100% apart .
Old 01-27-2012 | 11:08 AM
fishdip1's Avatar
I was thinking something like this set http://www.nopi.com/dsp_parts.php?vsubpcdesc=Engine Compartment | Engine - Rebuild Kit
BRONZE KIT - D15Z1 - 16V - SOHC Vtec - Contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable) and a set of expansion plugs - Also contains oil pump and water pump
Mfg# EKH21VB, NOPI# 102+0988
Old 01-27-2012 | 05:00 PM
fishdip1's Avatar
Any feed back is appreciated thanks.
Old 02-09-2012 | 11:28 AM
johnperdeye's Avatar
is this chris fish?
bullridingndn
06-25-2008 05:02 PM
97_ex
04-01-2007 03:06 PM
Travis71902
05-02-2006 11:10 PM
dalifts
09-16-2004 08:44 PM
dalifts
09-14-2004 09:31 PM
