problem after 5500 rpm, need urgent help
Old 11-01-2005 | 10:34 AM
gambino's Avatar
Default problem after 5500 rpm, need urgent help
Hi, i have a civic vti, (b16a2) .
After the vtec opens the cars slows down, its like before vtec the cars more faster.
You cant really feel it in the first gear , but 2nd, and e****ially 3rd, the head just goes down when the vtec opens.
so after 5500 its really bad, but at 7000 and after is a bit more better.
Any suggestions what the problem could be.
Old 11-01-2005 | 10:45 AM
gambino's Avatar
Default RE: problem after 5500 rpm, need urgent help
one more thing, i had my knock sensor missing, so there was the engine check light on, but when i inserted the knock sensor, the engine check light went off, but would i still need to reset the ecu.
Old 11-01-2005 | 11:52 AM
fast93civic's Avatar
I would recet the ecu, cant hurt. As far as vtec, when did you strat having this prob, just know or always?
Old 11-01-2005 | 12:46 PM
gambino's Avatar
well i bought the car , and i had this problem, as it was even worst, there was the engine check light, so i realized that the knock sensor wasnt there, so i bought one, and put it in, the engine check light went off.
But i stiil have to problem.
Old 11-01-2005 | 02:59 PM
Remmy's Avatar
dirty fuel injectors maybe?
Old 11-01-2005 | 03:54 PM
I dont think this would have much to do with it, but what kind of oil do you use, or did the previous owner use? Was it the right weight?
Old 11-01-2005 | 05:59 PM
gambino's Avatar
i use 10-40 mobil oil,
dont what the previous owner used.
why do you think it could be because of the oil?
Old 11-01-2005 | 08:42 PM
well, isnt it supposed to be more like 10w-30 and not 40? Oil pressure is what oppens the vtec so to speak. I suppose if the oil weight isnt right the vtec wouldn't engage properly, but I dont think this is the problem in your case.
Old 11-01-2005 | 08:51 PM
sacicons's Avatar
i would say first thing, reset the ecu, then check the timing.
Old 11-02-2005 | 10:18 PM
gambino's Avatar
ive reset the ecu, and re-checked the timing but still have to same problem
