Only running on 2 cylinders
Old 04-13-2007 | 11:59 PM
shockermotorsports's Avatar
Default Only running on 2 cylinders
I justswapped ab18bin my 97 civic with plans to boost. It is a b18 block with a b20 head. The first time it started it ran for about 15 min then it blew a headgasket. I had the head re-surfaced and reinstalled with ARP studs. Did a compression test and cylinder 2 was a little bit low but still within limits. All four cylinders were firing. When I started up the second time only cylinders 3 and 4 are working, 1 and 2 do not fire. I replaced all spark plugs and both 1 and 2 are getting spark. Any suggestions on what I should do to get other two cylinders running?
Old 04-14-2007 | 02:53 AM
TheMoogly's Avatar
Default RE: Only running on 2 cylinders
I just watched the mythbusters... mixing mothballs into the gasoline actually causes a higher octane level... you know I really wasted your time on this one....
Old 04-14-2007 | 09:15 AM
you need three things..
Spark
Compression
and Fuel
Sounds like spark and compression are good, what about fuel? What injectors are you running? Maybe two of them are ****
Old 04-14-2007 | 10:43 AM
johnny's Avatar
ORIGINAL: Forty04
Spark
Compression
and Fuel
Yee, maybe they are all coroded.
Old 04-14-2007 | 05:18 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
sounds like you are not getting fuel like forty said. check to see if the plugs are wet and smell like fuel, if they dont then you will need to get two new injectors.
Old 04-14-2007 | 08:43 PM
Just running on stock injectors right now... ill take them out and see what I find. thanks
Old 04-14-2007 | 08:54 PM
ya thats what i meant, you will have to get two new stock injectors if you are not getting any fuel on your plugs
BlakeryBob03
10-01-2013 05:22 PM
kenji51590
09-20-2011 09:45 PM
hondaT
03-04-2008 08:50 PM
RiceBurner
02-06-2005 05:40 PM
RiceBurner
01-16-2005 10:09 PM
