Which oil grade?
Old 05-23-2006 | 05:15 PM
rikstaker's Avatar
Default Which oil grade?
I live in a very hot place - Saudi Arabia,I own a brand new civic 2006,so can you help me deciding the right oil grade for my car?
Rik
Old 05-27-2006 | 04:02 PM
rikstaker's Avatar
Default RE: Which oil grade?
help pls
Old 05-27-2006 | 04:44 PM
importcivicus's Avatar
what type of oil is in it right if u know. Then maybe I will be able to help u out on the oil upgrade.
Old 05-27-2006 | 08:40 PM
Fiirkan's Avatar
your best bet for oil is to go with the factory spec oil it should say in you owners manual
Old 05-27-2006 | 10:05 PM
Nail I3unny's Avatar
mobil 1 10w-30
Old 05-28-2006 | 08:04 AM
rikstaker's Avatar
they factory is 20w-50! & some locally made saudi dino(sounds like crap) I am thinking thats why my fuel economy sucks: 19mpg city.
My manual simply says use any API service SL or higher grade oil & select the proper sae viscosity oil according to this chart:
0w-20,ow-30 & ow-40 are given spanning over ambient temperature range -20 to 100 degrres F
5w-30 & 5w-40 span over the same range as well.
10w-30 & 10w-40 span the range from 0 to 100 degrees f.
15w-40 spans from 10 degrees f to 100.
I wonder whats the point of that chart!!??? [&:]
it doesnt recommend any specific grade at all.
help me guys.The guys at the factory are morons(locals) I asked them which grade you use,they said it was 50w!!! I undesrstood it was 20w-50.
BTW-Ambient temperature ranges from 25-40 degrees celsius.
Old 05-28-2006 | 09:22 AM
rikstaker's Avatar
here is the chart
logeoff
08-18-2008 11:23 AM
oilltd
06-10-2008 05:06 PM
99hondo
01-17-2008 12:27 PM
jsoSoCal
03-16-2006 07:18 PM
