No Spark
No Spark
Well I just replaced my ignition module(igniter), Rotor, cap, PCV valve, Plugs and wires and fuel filter. I went to go start it and it wouldnt and it turns out I have no spark. I popped apart the distributor to check and all the wires are connected fine. I was wondering if the spark plug wires being connected in the wrong order could cause this. If so does anyone have a site or something that shows which wires go where on the cap. IF it isnt this the only thing I could think of would be a broken wire somewhere. Oh yea its a 1989 DX
RE: No Spark
I had problems before I worked on it but it still started fine. It would die whenever it heated up because of the ignition module. I had the coil checked and its fine. Checked the fuses they are all fine. Tried jumping it and that didnt work. I had my dad and uncle go over it also. SO the only thing I can think of would be a broken wire
edit: I havent checked the resistance on the wires but the wires and plugs are both brand new. But Ill check that tommorow just in case.
