new cams
Old 12-12-2004 | 04:35 PM
ballplaya4eva07's Avatar
Default new cams
If i get a new cam for my sohc vtec, what will it do for my perfomance? What exactly do cams and camshafts do?
Old 12-12-2004 | 05:08 PM
D16z6's Avatar
Default RE: new cams
Im not sure what the difference between cams and camshaft but i like to call them camshaft. Anyways i heard that its kinda hard to install camfshaft since you gotta kinda take your engine apart.
Old 12-12-2004 | 06:37 PM
Kappa22's Avatar
Jus to clarify, the cams are on the camshaft(s). They are the lobes that activate the valves. It's actually not very hard to replace camshafts. You just have to be very very careful. With SOHC engines, you have to take the entire valvetrain off and keep it clean and assembled. After that, you just have to remove the cam gear(s) and the camshaft retainers (on the ends) and it should come right out. You probably want to find some directions if you want to do it yourself.
Old 12-12-2004 | 06:43 PM
will aftermarket cams help with performance? Also should i replace just my cam or the comshaft too?
Old 12-12-2004 | 07:25 PM
sacicons's Avatar
its all one piece. and yeah, it will help noticeably. but you should probably do other mods first. like the standard intake/header/exhaust.
Old 12-12-2004 | 07:30 PM
XCM828's Avatar
ORIGINAL: ballplaya4eva07
Yes they help with performance, mostly by having more agressive cam lobes and changing the amount of overlap. You need to make sure you get a camshaft that is right for your car. Don't get one for super high performance car with like 400hp, because it will just be bad for your engine. Like stated above, the cam, or cam lobe, is actually part of the camshaft, and you cannot replace just single cams (or at least not very easily as far as i know). There are many cams on a camshaft; for a SOHC engine with 16 valves, there would be 16 lobes on the camshaft, one for each valve.
Old 12-12-2004 | 11:56 PM
Kappa22's Avatar
On a SOHC VTEC (like ballplaya4eva07's) I believe there are 20 lobes on the camshaft.
Old 12-13-2004 | 09:42 AM
Blackhatch124's Avatar
also you should probably (depending on the new cam you get) think about replacing your valve springs
Old 12-13-2004 | 10:22 AM
How many new cam gears will i need to replace them all? And only 1 camshaft right?
Old 12-13-2004 | 01:13 PM
Kappa22's Avatar
SOHC = single cam gear.
And yes, only one camshaft
Quick Reply: new cams
