Misfire w/o CEL?
Old 12-03-2007 | 04:31 PM
asdfbrendan's Avatar
Default RE: Misfire w/o CEL?
I'm gonna check the timing, go down the misfire diagnosis list/chart, and then try and get my hands on a scanner. I recently replaced my IACV w/ a used one I purchased. I'm not sure how clean it was, so I'll start there. What should I use to clean it? Brake cleaner?
  #32
Old 12-03-2007 | 05:50 PM
Sounds like a good plan. I've heard carburetor cleaner is the way to go for the IACV.
  #33
Old 12-06-2007 | 06:48 PM
Alright, here's my plan for the weekend:
Replace Dizzy cap and rotor
Clean TB and IACV
Seafoam that bitch
  #34
Old 12-18-2007 | 08:15 AM
Update
1.) Replaced cap and rotor; Cap had what appeared to be grit/build-up on one of the four terminals. And the rotor appeared brown and discolored (burned?).
2.) Cleaned out IACV w/ carb cleaner (alot of black **** came flying out).
3.) Seafoamed it.
Car seems to be running much better now. Popping/shuddering is 90% gone...but it's not 100% yet. Now the car seems to idle a little too low <500 rpm (which I assume is the cause of the occasional shudder/near stall). Hopefully today I'll be able to tweak the idle so it runs a little higher. Gas mileage seems much improved and the new wideband O2 hasn't thrown any CELs yet. I'm crossing my fingers adjusting the idle screw will fix my problem. Thanks again for your input, RonJ!
  #35
Old 12-18-2007 | 08:39 AM
That's great news! I look forward to hearing that the engine's running 100% when the idle is adjusted.
  #36
Old 12-20-2007 | 08:24 AM
Got another question...what's the name of the goop used to keep the idle screw from coming out? I'm assuming once I adjust it I'll need to re-goop it, right?
  #37
Old 12-20-2007 | 08:36 AM
ORIGINAL: asdfbrendan
Not sure. The idle screw for my 97 Civic is simply protected by a plastic cap insert.
  #38
Old 12-20-2007 | 11:55 AM
jamned's Avatar
The idle screw for my 87 (carbed) civic is unprotected under the air cleaner box (which is on top of the carb). I guess the air cleaner box keeps most stuff from touching it.
The idle screw on my 86 (FI) crx is unprotected. It's pretty exposed on the side of the throttle body. If you're worried about vibration loosening the screw, you could buy some threadlocker and apply it to the screw. I'd first drive for a week or two just to see if vibration (or anything else) would offset the screw.
KingDakota12
03-30-2011 09:23 AM
TGriffin
06-21-2010 10:58 AM
2KCIVCX
07-21-2005 04:16 PM
2KCIVCX
07-13-2005 02:11 PM
INJENalltheway
01-25-2005 04:10 PM
