Misfire w/o CEL?
RE: Misfire w/o CEL?
ORIGINAL: asdfbrendan
I've got one more question...The cylinder #s are 4-3-2-1 from left to right, right?
The picture also may be helpful to you.
[IMG]local://upfiles/25538/2A1088DB692A4F7E8A3EB5F9B43EB233.jpg[/IMG]
Hehe. I was just looking at the same chart trying to figure it out. Here's the deal: I converted my CVT (which uses a standard narrow-band primary O2 sensor) to A 5-speed (which uses a wideband primary O2 sensor). I just put in the wideband O2 sensor today (which got rid of the CEL I had for several months) and I replaced my ignition wires w/ NGK wires today too. Since I'm not getting a CEL, I'm assuming my new O2 sensor is functioning properly.
So, that means it's probably the ignition wires, right? Should I pull them one at a time while running and see if the idle changes?
