left front motor mount and bolt problems
Old 03-17-2007 | 11:58 AM
daveroc's Avatar
Default left front motor mount and bolt problems
Ok does anyone know the trick to getting off the left front motor mount ona 99 civic. Just did a timing belt / water pump job and figured that I would change all the belts. Well not the AC one since it is around the motor mount and the nut for the mount is now broken up inside the frame. What to do? Weld the mount to the frame? Any ideas how to get to it.
Old 03-17-2007 | 01:29 PM
droopy128's Avatar
Default RE: left front motor mount and bolt problems
oooo.. once the mount is off.. try to use a drill and extractor to remove it..
Old 03-17-2007 | 04:57 PM
daveroc's Avatar
Found a way....!!!!! You will love this.... The nut was only welded on three of the corners and it broke loose. With no way to access the nut I drilled a 1+ inch hole through the sheet metal frame and now can get a box wrench on the nut and that's the story. I hate to say thank you to Honda to hide the welded nuts inside the frame with no access at all. Hey Honda please fully weld the nuts in place because you know that at 100K you have a little rust inside the frame.
Old 03-18-2007 | 10:04 AM
I would put a little spray paint or something on the hole that you drilled, to help prevent rust
ride2clean03
09-08-2011 12:46 PM
cjy01
02-22-2011 03:17 PM
Peg_Leg
XBox/XBox 360
05-07-2010 07:42 PM
jds62f
04-25-2010 07:01 AM
reaper2022
Routine Maintenance DIYs
01-28-2010 03:53 PM
