k20a3
RE: k20a3
Because if it is only 150 then it probably has more than just a few bent valves. Also make sure you know what it takes to get that k20 into your car. You are going to have to buy a lot more than just the engine plus it is just plain a lot of work so if you do it then you are going to have to know what you are doing or have a lot of money to pay someone else to do it.
RE: k20a3
No because you can get a complete K24 w/o burnt valves for around $500 and the A3 bottom end is just not the ideal starting point. It is like starting with a D15A2 when you could get a D16Z6 for just a little bit more.
