K20 Cams/Pistons/Crankshaft fit into a B16A?
RE: K20 Cams/Pistons/Crankshaft fit into a B16A?
you will raise compression around .1 or .2 points and coupled with the cams may make 15 to 20hp at the most with a oem b series 3 layer head gasket
if you use CTR pistons and a oem 1 layer b series head gasket you could see compression jump to around 11.5 to 1. Fully tuned you could see 200whp maybe
also, check this thing out
http://technet.ff-squad.com/cr-calculator.htm
Captain_Sl0w
03-17-2008 09:27 AM
Captain_Sl0w
02-17-2008 09:25 AM
