Idling at 200 rpm
Idling at 200 rpm
i took the supercharger off my d series a couple weeks ago and it ran fine with putting all stock components back on. then i decided put on an Edelbrock performer x intake manifold along with a dc 4-1 header and test pipe. now im running at about 200 rpm when the engine is warm and in both park and drive. i tried setting the idle speed screw to 650 with the iac unplugged to reset the idle speed but when i do it makes the engine idle surge up and down when the iac is plugged back in. so i moved it back to where it was in the beginning... anyone have this problem? do i just need to adjust the timing a few degrees?
Yes, for the z6, you disconnect the IACV to set the idle; however, you set it to 420 rpm using a good tachometer:
If you still have an idle problem after following this procedure, then try cleaning the IACV (see forum DIY).
Also inspect your spark plugs. If burned or worn, replace them.
Alan562
07-11-2005 03:57 AM
98brokeassvtec
08-26-2004 11:38 PM
