HELP. is thios dangerous?
Well i just installed red cold air intake and i thougth i need to change the little hoses from the throthel body.. well i replace some coolanc hoses in the throttle body with some cheap flexible rubber red hoses. im i at risk for they to broke or just melt considering hte extreamly hot temperature from the coolanc???
RE: HELP. is thios dangerous?
You're extremely difficult to understand. There shouldn't be any coolant going to the throttle body. If you're talking about the vacuum lines then you don't have much to worry about. If you changed the heater lines or radiator hoses then you need to make sure the hose is rated for that.
matty1313
02-08-2014 12:45 PM
coronakid
02-16-2006 01:31 PM
