Head Studs Necessary
Old 03-29-2006 | 01:38 AM
Pete's Avatar
Default RE: Head Studs Necessary
It seems like the mods wont stop there.......have them use ARP headstuds.....or just put em in urself down teh line
Old 03-29-2006 | 02:31 AM
Marty's Avatar
Buy a set of ARP's they will pay for themselves in the long run
Old 03-29-2006 | 05:28 AM
Street Sniper's Avatar
ARP's are worth it, but they aren't absolutely necessary. You can get away with stock replacement right now. The thing is, is that the stockers aren't reuseable (or not supposed to be) becasue they stretch when they are torqued down. ARP head bolts keep the head under compression instead of under tension like the stockers.
By the way, you are gonna need to mix and match the head bolts anyway to get a z6 head on a y8 block. One of the y8 studs is gonna be too short for the z6 head. Also, the cam timing between the z6 and y8 are 4.5* off, make sure you compensate with that cam gear.
Old 03-29-2006 | 02:46 PM
Kappa22's Avatar
ORIGINAL: Street Sniper
Actually this is a fairly common misconception. On a stock [Honda] engine, the head bolts don't actually stretch when torqued to spec; they twist slightly, and release when broken loose. They are actually perfectly reusable 2 or 3 times (just for safety's sake).
Old 03-30-2006 | 01:06 AM
Clean98EX's Avatar
this sucks the cam gear won't be here till after the work is done. will it be possible to install the cam gear after i get the head swap done. can it run with the 4.5 degree difference? is it advanced or retarded?
jaymacf3
05-15-2006 02:02 AM
Clean98EX
02-21-2006 08:45 AM
95lsvtec
02-14-2006 11:46 PM
Chimera02EX
09-23-2005 07:02 PM
Chimera02EX
09-11-2005 08:41 AM
Quick Reply: Head Studs Necessary
