Head Milling vs. Larger Piston!!!
Old 08-28-2006 | 11:59 AM
mentaldis0rder's Avatar
Default Head Milling vs. Larger Piston!!!
Just like it says .. what are pro's cons vs each.. base for those that dont know i have a Y7 block and going to be doing a MINI ME but am having full headwork done prior to install and also wanted to refresh bottom end with new rings/bearing/shotpeed rods etc.. but I used the compression calculator and seen with only slight milling of the head you can obtain upwards of 11:0:1 compression on stock piston.. just wondering vs buying some d16a1 pistons or aftermarket 10:5:1 pistons .. what are advantages of replacing the pistons .??
Old 08-28-2006 | 12:20 PM
Marty's Avatar
Default RE: Head Milling vs. Larger Piston!!!
The advantage is you can go slightly over bore and you would be able to spray on them. If your staying N/A w/o any other plans OE honda pistons will be fine.
Old 08-28-2006 | 12:38 PM
Kedawei's Avatar
You got the comp calculators working. Good. [sm=smiley20.gif]
This one is my favorite. http://www.zealautowerks.com/dseries.html
Since we're on the subject... kinda... what about block decking? How far can a block safely be decked?
Old 08-28-2006 | 01:15 PM
ef4life's Avatar
you shouldn't deck the block anymore than needed to keep it squared and true. same with the head imo, but i would rather not do either
Old 08-28-2006 | 01:32 PM
Kedawei's Avatar
Well yeah, if you did your pistons would be sticking out the block. I guess really I need to get the block in my hands before making any decisions about it...
pWnEdU's Avatar
I would just mill the head. That's what I would do anyways.
Old 08-28-2006 | 01:48 PM
glad i got some responses this time :P .. now if i can get some return input in same post about whether i can obtain around 160whp on my MINI ME build by only refreshing bottom and and getting full headwork done with stage 2 or 3 valvetrain and Neptune job.. by changing compression .. and what compression you think i should run?>The more i keep reading into NA the more im seeing people breaking into 13's N/A on D's ..
Old 08-28-2006 | 01:51 PM
ef4life's Avatar
i wouls say the maximum amount possible for a dd and street gas 91 octane or 93 octane.
Old 08-28-2006 | 02:04 PM
Kedawei's Avatar
If you can get E85 in your area, convert to that and push it's comp through the roof. E85 is rated at about 105 octane.
Old 08-28-2006 | 02:05 PM
Kedawei's Avatar
ORIGINAL: ef4life
This is something I've always wondered. What is the limit of our little D-series's on 91 and 93 octane, compression wise?
