engine swap
Old 12-12-2007 | 03:47 PM
eaton89's Avatar
Default engine swap
New to the world of honda. The motor in my boys car took a c**p. I have a 2000 2 doorcivicex 1.6 d16y8 sohc. What years will directly interchange. If I used a 1.6 motor out of a 91 92 will it work or will I need to change all the injection and other accessories with wiring. What are my opptions and what exactly do I need for the change. I would like to change possibly to a 1.6 dohc engine but what do I need to do it(engine tranny ecu axles mounts )? Anyone responding please give me ideas for both ways if you can. Thanks
Old 12-12-2007 | 04:17 PM
my05civic's Avatar
Default RE: engine swap
i don't know what engines will fit, but legally, you cannot swap an engine into your car that's older than the body.
ex. cannot swap a 2001 engine into a 2005 body
Old 12-13-2007 | 05:03 AM
eaton89's Avatar
Not a problem. We dont have emissions here. Never had a problem with that!
Old 12-13-2007 | 09:12 AM
95civic1.6l's Avatar
u can't find a replacement d16y8?
Old 12-13-2007 | 09:50 AM
cant_beat_VTEC's Avatar
dude go to tokyomotorimports.com you can find a y8 for about $400 comes usually with the transmission and ecu
Old 12-13-2007 | 07:52 PM
sandrider123's Avatar
okay so your 00 EX is OBD2B meaning only 99-00 engines will drop and plug directly in. 96-98 your going to have some wire conversions to do.
To change to B16 (DOHC 1.6) your looking at needing the following parts from a 99-00 civic si:
Rear tranny/motor T bracket mount (looks like a giant T)
drivers side motor mount
axles
power steering pump bracket
shift linkage
ECU
And then a A/C bracket from a Civic Del Sol.
This is all figureing the car is a 5 speed if its not then you have some extra work cut out for you
chbulldogs11@msn.com
05-27-2011 09:05 PM
skibum853
11-18-2007 09:40 AM
badboy4life
09-01-2007 08:28 AM
Kingzlei
05-05-2007 04:06 AM
silvr63vet
12-04-2006 03:55 PM
Quick Reply: engine swap
