Is this engine good for boost?
Old 08-02-2006 | 09:29 PM
Fejery4491's Avatar
Default Is this engine good for boost?
I wanna boost whatever engine I swap in.....I've been looking into the B18C1 but this was $800 less. Is this thing pretty much boost ready?
http://www.jazzproparts.com/ProductD...ductCode=B16a2
Old 08-02-2006 | 10:59 PM
dfdon's Avatar
Default RE: Is this engine good for boost?
just depends how much psi your gonna run it can handle effecintly 300 hp on stock internals
Old 08-03-2006 | 09:18 AM
ORIGINAL: dfdon
With a good tune that is
Old 08-03-2006 | 12:22 PM
Marty's Avatar
Generally the B16's are not ideal for boost as they have a higher compression ratio. Look for a GSR or a LS(B18B) swap.
Old 08-06-2006 | 01:20 PM
MY99SI's Avatar
there are 4 boosted si's in town here all of them are the stock CR and they love 10 psi all day long. even with the stock internals they can handle 300hp and 280tq.
Old 08-06-2006 | 05:26 PM
Kedawei's Avatar
ORIGINAL: MY99SI
That's about right for the hp @ 10 psi on a stock block, but you'd need at least a 400+ hp motor to make 280 ft/lbs of torque out of a b16. At 300 hp, 200-225 ft/lbs would be more accurate for the torque.
cderalow
05-04-2007 11:26 PM
usmc2b2004
02-27-2006 01:06 AM
str8racn
11-10-2005 12:53 PM
nachoman
05-23-2005 03:37 PM
smokingemcee
05-17-2005 04:18 PM
